Results 1 to 9 of 9
    Jon mackay's Avatar
    Jon mackay Guest
    Default Furnace vent initial rise
    I know that water heaters must have an 18" vertical rise befor the first transition.
    Is there a rule for gas furnaces?
    Default Re: Furnace vent initial rise
    I'm not aware of a 18" requirement for any gas appliance.
    This questions comes up here often, this is likely the most useful (if somewhat ... err.. contentious) iteration, see the second version of Jerry Peck's .pdf, near the middle of the thread.
    http://www.inspectionnews.net/home_i...ust-slope.html
    David Bell's Avatar
    David Bell Guest
    Most gas water heaters I have seen with draft hoods have a 6" requirement before any change in direction.
    Quote Originally Posted by David Bell View Post
    !2 inches.
    Show us where it only requires 6 inches.
    David Bell's Avatar
    David Bell Guest
    Here is an example
    Here is an example
    Thank you,
    Q. Now, however, when you take the code's connector rise chart minimum of 1 foot and try to match that with that manufacturer's drawing (do you know how old that is?) what do you end up with?
    A. The most restrictive shall apply. (From the codes.)
    David Bell's Avatar
    David Bell Guest
    Are those not B-Vent requirements? Show me single wall pipe requirements.
    Ron Bibler's Avatar
    Ron Bibler Guest
    I see this form time to time.
    Best
    Ron
    First, go back and review the drawing you posted.
