    Ft. Myers, FL
    Default Air handler emergency overflow
    What are the odds of the emergency pan actually working, and draining condensate water directly into the light below. Priceless.
    Paul Kondzich
    Ft. Myers, FL.
    Default Re: Air handler emergency overflow
    Makes it more "conspicuous" !
    David Bell's Avatar
    David Bell Guest
    Looks like it's happened before, the globe on the light has about 1/2 " water in the bottom of it and is algea covered.
    Ft. Myers, FL
    Quote Originally Posted by David Bell View Post
    Yes it had water in it, and the bulb was exploded.
    Paul Kondzich
    Ft. Myers, FL.
    Quote Originally Posted by Paul Kondzich View Post
    ...the bulb was exploded.
    It works! That's the signal to the home owner that there's a problem with their AC!
    Philip's Avatar
    Philip Guest
    Question Re: Air handler emergency overflow
    Are not the drip holes supposed to be directly above the door so the splash is on the stoop or porch. Or is that just common sense and not code.
    Ft. Myers, FL
    Not here, Alot of them, my house for example has the air handler in the garage and the pan is there but just has a PVC 90 that will drip in the garage, or your car so you know its leaking. In other words the PVC 90 is not connected to anything just drains on the floor. Like this.
    Last edited by Paul Kondzich; 05-22-2010 at 11:43 AM. Reason: Added pic, so these guys know what im talking about
    Paul Kondzich
    Ft. Myers, FL.
    Philip's Avatar
    Philip Guest
    Garage ok, but in the attic?
