Results 1 to 3 of 3
    dan orourke's Avatar
    dan orourke Guest
    Default air ducts in closet
    Martin lehman's Avatar
    Martin lehman Guest
    Default Re: air ducts in closet
    I would say that is compromises the fire separation between the floor/cieiling.
    Brian E Kelly's Avatar
    Brian E Kelly Guest
    If this is a compromise in the fire wall between floors then all the ductwork going up thru from the basement should have fire dampers where they penetrates each floor. I agree with Dan to note to protect from damage.
