    Default Corrosion/Deposit at Trane Furnace
    Any opinions/ information on the significance (or lack of same) of the corrosion/deposits at this furnace?
    Connecticut
    Default Re: Corrosion/Deposit at Trane Furnace
    Looks like 99% of the ones I've seen lately. Condensation leaks, Service and monitor.
    Succasunna NJ
    It looks like a drainage problem. I've seen quite a few of those little rubber drain hoses 'pinched' so the condensation doesn't drain.
    May 2007
    Frankfort, KY
    That unit is also not installed according to manufacturers installation instructions.
    Any 120,000 BTU furnace is supposed to have a return drop pulled from both sides or from the bottom but not one side only.
