Results 1 to 11 of 11
Thread: nice job
06-11-2010, 02:21 PM #1
nice job
I guess he didn't notice the window.
06-11-2010, 06:51 PM #2
Re: nice job
12" clearance to window seems fine to me, intake may be too far away tho, most manufacturers require it to be within 20" of exhaust to keep pressure switch happy
06-11-2010, 07:33 PM #3
06-11-2010, 07:34 PM #4
Re: nice job
So David, You would have no doubts at all of having your children play all afternoon in that basement area with the window open and the water heater running?
Not an attack, just an example to determine if I am overreacting.
I see it as the exhaust collection in the well and with the window open, entering the basement area. 12" or no 12" rule.
Just looks suspect to my overprotective mind.
06-11-2010, 10:10 PM #5
Re: nice job
Looks like a bulkhead door to the left of the intake will block airflow or might damage intake when bulkhead opened fully/unrestrained. Both alcove/pit type effects (bulkhead near intake and window well at exhaust) might be a headache with pressure/wind problems.
Basement window appears an operable one - and metal screen frame, is that the case?
From this view, also appears the exhaust vent is actually directing within the "footprint" confines of the galvanized window well and will drain within same. The clearance and such to this window well "wall" in addition to the basement window itself do seem concerning.
I'm thinking with the contrast and perhaps not having viewed other than the thumbnail view perhaps David Bell thought you were referring to the window grouping above (picture window flanked by two operable windows).
06-12-2010, 05:13 AM #6
Re: nice job
Thanks guys,
06-12-2010, 07:18 AM #7
06-12-2010, 12:13 PM #8
Re: nice job
To all, the exhaust side is near the bulkhead, the intake near the basement window. From strictly a code standpoint it is compliant, whether or not I would let my kids play nearby is not the issue. It has the 12" required from the window above.
06-12-2010, 12:52 PM #9
06-12-2010, 01:41 PM #10
Re: nice job
The exhaust side is pitched back to the unit for drainage purposes not needing an elbow on it to prevent water or other contaminates from entering. The only problem I see is a concentric reducer on the end of the exhaust, while a reducer may be ok, it should be eccentric to allow condensate to escape the pipe easily.
06-12-2010, 02:35 PM #11
Re: nice job
The installation guide will (should) state the termination should be 12" above the anticipated snow level.
Here in NJ, the anticipated snow level is 6 inches so the termination should be 18 inches above the grade.
You need to find out the anticipated snow level in Conn,.
