    M Kelekci's Avatar
    M Kelekci Guest
    Default Secondary drain overflow shut-off
    If there is no secondary drain overflow shut-off wired in, do you guys write it up? If you do, as a repair or recommandation?
    Thanks,
    Richard Rushing's Avatar
    Richard Rushing Guest
    Default Re: Secondary drain overflow shut-off
    Matt,
    That depends...
    If the secondary drain pan has a drain line, is properly plumbed and is run to a conspicious locations... no. No shut off switch required-- nice to have, but not required.
    M Kelekci's Avatar
    M Kelekci Guest
    Quote Originally Posted by Richard Rushing View Post
    Matt,
    That depends...
    Thanks Richard,
    Let me ask you this,
    Does having a shut off switch if there is no proper secondary drain pan provided meet the code that requires proper secondary drain? or still need to be reported as in need of repair?
    Quote Originally Posted by M Kelekci View Post
    There can be either a cut off switch in the secondary drain pan or a drain line ... or both ... but there must be one or the other of them installed.
    M Kelekci's Avatar
    M Kelekci Guest
    Thanks,
