    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Slope of furnace vent
    Garage furnace with an induced draft vent. It is allowed to slope downward? Could not find any installation instructions. Place was built in 07
    Default Re: Slope of furnace vent
    I don't see those types of units around here.
    Is that a condensate stain on the plate beneath the flue pipe?
    No way.
    The Simpson Dura-Vent instructions I have say that any "horizontal" sections must slope upwards away from the appliance at least 1/4" per foot. I don't think it would say that if you were allowed to vent vertical sections down as shown.
    Induced draft is still considered natural draft and must be installed as such. As John said, needs correct slope.
    Utah
    Thumbs down Re: Slope of furnace vent
    Agreed as flat out wrong.
    David Bell's Avatar
    David Bell Guest
    Also, clearance from venting to gas pipe not good, no sediment trap on gas line, clearance of unit to ceiling could be suspect.
    Scott Craig's Avatar
    Scott Craig Guest
    Must admit, I have never seen a set up like that! But really looks wrong. Don't think it should ever slope down!
