    mike huntzinger's Avatar
    mike huntzinger Guest
    Default water heater failure
    found this inside the burner of a 16 year old wh. i think it is the flue pipe difusser
    Default Re: water heater failure
    "found this inside the burner of a 16 year old wh. i think it is the flue pipe difusser"
    Yes, that looks like it.
    Mar 2008
    Charlotte NC
    Quote Originally Posted by mike huntzinger View Post
    More common name is "baffle".
    Cool Re: water heater failure
    turbulator by some mfrs. Otherwise, flue baffle very common. These usually have 'wings' at the top so they are suspended. Not a good sign but this WH needs to either be replaced or at least really gone over by a pro.
