    Apr 2008
    McKinney Texas
    Default Extra copper line at Evaporator. See photo.
    Extra copper line at Evaporator. Maybe I am overtired but don't recall seeing of these before. What is extra copper line ?
    Zibby Bujno's Avatar
    Zibby Bujno Guest
    Default Re: Extra copper line at Evaporator. See photo.
    looks like a test port brazed in suction line by installer. Waste of part/money.
    Apr 2007
    gainesville fl
    ditto on service port and waste of $$$ pressures should be checked at the condenser
    Factory installed port. Lots of units have them.
    Bob Cone's Avatar
    Bob Cone Guest
    It is likely an external equalizer port connection for use with a thermostatic expansion valve.
    Houston, Texas
    Quote Originally Posted by Gene South View Post
    Its factory installed and is used to enter, and subsequently relieve, the shipping pressure in the coil (usually just dry nitrogen).
    Contractors use this to quickly verify that the boxed coil they are buying has held its shipping pressure upon pickup at the loading dock. If there is low or no pressure left in the coil then he will not accept it.
    After installation it serves no particular purpose.
