    Nampa, Idaho
    Question Scary looking vent pipe.
    This is in original 1930 oil furnace converted to gas. The flue pipe has a box or some type of damper installed. It is open on the bottom, I would think that something is missing here. Has anybody seen anything like this before?
    David Banks's Avatar
    David Banks Guest
    Default Re: Scary looking vent pipe.
    I believe what you have there is a draft diverter that is on vent instead of part of furnace unit itself.
    Gary Schutta's Avatar
    Gary Schutta Guest
    That is an old draft diverter & should of been capped off so the new gas furnace will draft properly.
    Gary
    May 2007
    Frankfort, KY
    If that is a homemade drafthood it is as illegal as the day is long.
    It has to have an AGA stamp on it to be approved, besides a double acting barometric would be much more effective.
