Thread: plant that thing
02-11-2011, 08:18 PM #1
plant that thing
picture says enough
02-12-2011, 08:00 AM #2
Re: plant that thing
Must be a ground source heat pump!
02-12-2011, 09:53 AM #3
Is that inset dk gray square above housing the disconnect too?
02-12-2011, 04:30 PM #4
Could you determine how that stone was installed? One inch air gap? Manufactured stone or real? Looks real but its hard to tell from a picture.
Any signs of leaks at the baseboards or walls?
www.BAKingHomeInspections.com
02-12-2011, 04:35 PM #5
Yes, disconnect embedded in the stone veneer.
Water intrusion issues highly likely with this lick 'em and stick 'em veneer. No flashings visible at sills that slope back towards the house. Only a bit of caulk.
02-13-2011, 11:07 PM #6
02-14-2011, 08:17 AM #7
