Results 1 to 13 of 13
Thread: What kind of vent pipe?
04-07-2011, 10:47 AM #1
What kind of ridged pipe (air duct) do you suppose this is (or call it).
It is running from the gas heater (air distribution) in the basement to the an upstairs room that is on a concrete slab. Home built 1970. I don't want to say the "A" word if I don't need to. It sounds like a clay tile pipe when you "rap" on it.
04-07-2011, 11:03 AM #2
Re: What kind of vent pipe?
Looks like transite, which is an asbestos containing product.
04-07-2011, 01:02 PM #3
Thanks Scott,
Thats what I was thinking but I couldn't remember what it was called or if it did contain Asbestos. I remember seeing this years ago used for sewer pipe. I will be reporting it as such. I am guessing that all the other ducts under the slab is this way, probably several hundred feet.
04-07-2011, 01:37 PM #4
04-08-2011, 04:01 AM #5
Transite is a trade name.
It is actually called asbestos-cement.
04-08-2011, 04:23 AM #6
Actually transite pipe started out as a trade name "Transite" made by Johns-Manville, but morphed into a generic term for the pipe even though it was made by different companies. The new "transite" pipe does not contain asbestos by the way.
04-08-2011, 04:34 AM #7
So Larry
I would never tell your customer the "A" word unless you have test results.
I would say you recommend it be tested for the "A" word.
04-08-2011, 05:36 AM #8
04-08-2011, 05:48 AM #9
Agree! That is the way I have worded the report. So, I gave them a link to do more investigation of the product ...This is a home were "I am earning my money". Also has a "Zensco" Elec-Panel...and no ground to recepticals... and a roof system that needs beefed up. (sags)
I'm getting an 'invaluable' education on this one...at least that is how I keep smiling.
04-11-2011, 01:47 PM #10
Again, why are these posts not listed where they should be???
I'm a dyslexic agnostic-Don't believe there is a dog...
04-11-2011, 05:03 PM #11
The header is.....
InspectionNews - Home Inspection» Technical Topics For Home, Commercial & Environmental Inspections» Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection» What kind of vent pipe?
Where should they be, if not here?
02-25-2012, 10:08 PM #12
02-26-2012, 09:29 AM #13
