04-09-2011, 05:56 PM #1
Max Vertical lift of Condensate pumps?
Anybody got a guess at what the maximum vertical lift a condensate can pump water?
Today's basement had a 16 foot ceiling
and the condensate pump was trying to lift water from the basement floor up and out the sidewall about 3 feet above grade level. Roughly 19ft, over a hairpin turn in the flex line.
There was rust running out of the A/C unit so presumably the condensate lines were backed up.
Tried posting pics but apparently there are too large.
Similar Threads:"The Code is not a peak to reach but a foundation to build from."
04-09-2011, 05:59 PM #2
Re: Max Vertical lift of Condensate pumps?
04-09-2011, 06:11 PM #3
Here is a site that shows your basic pumps. It looks like you are right at the cut-off point for the smaller ones.
Hartell Condensate Pumps
04-10-2011, 01:56 AM #4
Also be sure the discharge line is properly sized.
04-10-2011, 10:02 AM #5
Thanks! Should have googled around a bit. Looks like common sizes provide 13'-15' of lift. Probably undersized pump for the particular installation.
