Results 1 to 9 of 9
    Mar 2010
    Prairie du Sac, Wisconsin
    Default Chimney material. Is this an asbestos product?
    I saw this older chimney today 1950's 60's vintage home. It is encased in what looks like concrete but when tapped on sounds more like a light weight carboard or paper material. anyone know what this could be. The old chimney ports are closed off and the other 2 vents look more recently updated.
    New York
    Default Re: Chimney material. Is this an asbestos product?
    looks like asbestos
    homeinspectionsnewyork.com
    eifsinspectionsnewyork.com
    Asbestos? Until it's lab tested I wouldn't go any further than it might be, could be, or may be. "I dunno" is also a safe answer.
    Given the circa of the home it is likely it contains asbestos, but if anyone is in doubt a test would confirm.
    Looks like asbestos transite pipe. More than likely manufactured at the now defunct Johns-Manville plant in Waukegan,Illinois.
    ILD005443544, NPL Fact Sheet | Region 5 Superfund | US EPA
    www.dapkusinspections.com
    www.chicagoinfraredthermalimaging.com
    Infraspection Institute Certified Level III Thermographer # 8510
    Jul 2010
    Kansas City Missouri
    Is the flexible vent an approved vent. It kind of looks like a dryer type vent that is attached with a hose clamp in the picture.
    Galen L. Beasley
    Inspections Supervisor
    Housing Authority of Kansas City MO
    Mar 2010
    Galen, Your point is a good one. I should have inspected that better. I don't believe I can dismantle that but a few taps may have at least indicated an insulated wall or just a hollow. It does look like regular aluminum dryer vent.
    "Transite" Do a search for it here. But only if you want to.
    Quote Originally Posted by Galen L. Beasley View Post
    Galen it could be stainless steel- one piece liner. Also that is not a wye connector its a tee and I believe it to be wrong.
