Results 1 to 9 of 9
04-14-2011, 04:43 PM #1
Chimney material. Is this an asbestos product?
I saw this older chimney today 1950's 60's vintage home. It is encased in what looks like concrete but when tapped on sounds more like a light weight carboard or paper material. anyone know what this could be. The old chimney ports are closed off and the other 2 vents look more recently updated.
04-14-2011, 05:13 PM #2
Re: Chimney material. Is this an asbestos product?
looks like asbestos
04-14-2011, 07:33 PM #3
Asbestos? Until it's lab tested I wouldn't go any further than it might be, could be, or may be. "I dunno" is also a safe answer.
04-14-2011, 07:42 PM #4
Given the circa of the home it is likely it contains asbestos, but if anyone is in doubt a test would confirm.
04-15-2011, 03:05 AM #5
Looks like asbestos transite pipe. More than likely manufactured at the now defunct Johns-Manville plant in Waukegan,Illinois.
ILD005443544, NPL Fact Sheet | Region 5 Superfund | US EPA
www.dapkusinspections.com
www.chicagoinfraredthermalimaging.com
Infraspection Institute Certified Level III Thermographer # 8510
04-15-2011, 06:19 AM #6
Is the flexible vent an approved vent. It kind of looks like a dryer type vent that is attached with a hose clamp in the picture.
Galen L. Beasley
Inspections Supervisor
Housing Authority of Kansas City MO
04-15-2011, 09:35 AM #7
Galen, Your point is a good one. I should have inspected that better. I don't believe I can dismantle that but a few taps may have at least indicated an insulated wall or just a hollow. It does look like regular aluminum dryer vent.
04-15-2011, 02:04 PM #8
"Transite" Do a search for it here. But only if you want to.
04-15-2011, 02:48 PM #9
