Thread: dryer duct construction
05-11-2011, 01:27 PM #1
In the 2006 IRC, where it says that clothes dryer duct joints should run in the direction of air flow, that means the male ends should be pointing in the direction of air flow so lint doesn't get caught, right?
I keep seeing it done backwards, so just checking.
05-11-2011, 02:48 PM #2
Re: dryer duct construction
Yes that is exactly what IRC G2439.5 says: "The male end of the duct at overlapped duct joints shall extend in the direction of airflow." But, since the reason is not stated in the code, we can only guess why, and lint could be 1 of several reasons.
05-15-2011, 12:25 PM #3
exhaust gases need to stay in the vent pipe until it gets outside
05-15-2011, 02:31 PM #4
If I see metal duct and not the flexible vinyl or metal material I usually let it slide. Also the joints are usually taped so you can't tell which way the joints face anyways.
05-15-2011, 03:47 PM #5
05-15-2011, 03:48 PM #6
05-15-2011, 04:01 PM #7
05-17-2011, 05:59 PM #8
John
That is correct. It is to stop lint from collecting and that is also the reason for not allowing any fasteners to penatrate it.
