Thread: What Is It
05-18-2011, 08:49 PM #1
05-18-2011, 10:21 PM #2
Re: What Is It
I asked your question and picture over on the HVAC board and got the following:
A thermal expansion valve is a component in an air conditioning system that controls the amount of refrigerant flow into the evaporator thus controlling the superheat at the outlet of the evaporator.
05-19-2011, 06:31 AM #3
Re: What Is It
Here is a basic explanation of a TXV for HVAC systems.
Dom.
05-19-2011, 04:42 PM #4
Re: What Is It
Thanks. That's definitely it.
05-23-2011, 07:24 AM #5
Re: What Is It
You will see a TXV on (usually) systems of higher capacity OR ones that have had problems with frosting the coil. As I recall the newer systems with R410a refrigerant don't get as cold and the frosting issue is less of a concern.
05-23-2011, 08:37 PM #6
Re: What Is It
TEV. Like others said, higher efficiency units will have. Next step up from cap tube.
