Results 1 to 3 of 3
Thread: Whistling vent
05-23-2011, 07:17 AM #1
Whistling vent
Just checking on this.
When a steam system register vent has a whistle.
Does this indicate that the vent is worn and in need of replacement, or is it ok as long as steam is not escaping?
05-24-2011, 04:40 AM #2
Re: Whistling vent
Whistle is evidence that steam is being released and that is good. The valve is for presure relief which is needed in a high pressure system, safety release. If no escaping steem then system could blow up. Some valves will act as a air purge to allow a better flow of steam. Valve shuts when hot. It is all dependent on how your system was designed. Get a qualified plumber to check your system out including all valves.
05-24-2011, 06:06 AM #3
Re: Whistling vent
Good steam vents tend to 'whistle' more. The cheapo ones at the big box store tend to 'piss' more.
Good vents are pricey =/-$20 depending. The cheapo ones are like 5 or 6. Vents are also categorized/sized for where in the system they are. Main vent, intermediate run vent, vent way at the end of the run, etc.
