    Default Is this a heat pump?
    This is a furnace in a 5 story loft. I have never inspected a unit with water lines. The roof units did not appear to be heat pumps, but the thermost has an emergency heat function.
    Trane GEVB03611M0130TL000000010000000000
    This unit was crammed into the top of a closet and I could net get a good look.
    Thanks and have a good weekend.
    Default Re: Is this a heat pump?
    Every water-to-air unit I've seen has been a heat pump.
    Especially with that maximum 35 amp breaker/fuse.
    Looks like they had to re-pipe the water for some reason?
    James Duffin's Avatar
    James Duffin Guest
    The data tag says it is a WSHP which I believe to be a water source heat pump. Was the system using wells or a low temp boiler and cooling tower?
    The unit did not have a water heater. The buyer said it was public water but I could not get access to the "boiler area".
    So if it is a colling tower set up is there a condeser as in a traditional colling system?
    There are condensers on the roof but they did not have assignments.
    James Duffin Guest
    Quote Originally Posted by Dan Sandweg View Post
    I don;t believe that condensing unit is a part of the WSHP system. The unit in your first post is a package system.
    Don Burbach's Avatar
    Don Burbach Guest
    Google is YOUR friend. When I have something concrete I often use a google type search. In this case I guessed that I could use GEVB036 as a search argument.
    I found all sorts of hits that describe this unit.
    TRANE GEVB036 Heat Pumps describes it as a:
    The TRANE GEVB036 is a residential water/brine to air packaged-unit heat pump.
