Thread: Any ideas what this could be?
06-21-2011, 07:29 AM #1
Saw this in the back yard of a home built in 1970. It looks like some sort of air intake but its located at the far left corner of the home behind the garage which is on a slab. Its also right next to a downspout that is draining at grade level. Any ideas? Maybe the downspout was previously hooked up to it? Any thoughts would be appreciated.
Similar Threads:Last edited by Stephen G Sheldon; 06-21-2011 at 07:35 AM. Reason: no photo
06-21-2011, 09:00 AM #2
06-21-2011, 11:42 AM #3
Re: Any ideas what this could be?
My approach is to write such things as unknown and let the buyer ask the seller. You might be right about a downspout previously being connected to it - but what if you're not? I try to avoid assumptions and I advise my clients to do the same.
06-21-2011, 12:23 PM #4
There is a radon mitigation system but it clearly vents through the roof
06-21-2011, 01:08 PM #5
06-21-2011, 07:28 PM #6
Bruce Thompson, Lic. #9199
www.TylerHomeInspector.com
