Results 1 to 14 of 14
    Sep 2009
    Twin Cities, Minnesota
    Default Dryer vent/AC condenser clearance
    Is there a building code for how far apart the dryer vent should be from the AC condenser at the exterior for residential homes?
    -Jon
    Errickson Home Inspections, LLC
    http://www.erricksonhomeinspections.com
    Default Re: Dryer vent/AC condenser clearance
    Quote Originally Posted by Jon Errickson View Post
    Nope.
    * But Code doesn't Stop Stupid.
    ** Or Even Address Common Sense.
    There may not be anything in the code but I am sure HVAC manufacturers will have some standard. I would not put one within 6 feet!
    http://www.jjeffzehnder.com/
    I've never seen a specific condenser manufacturer's requirement for dryer vent clearance, and the the dryer manufacturer's instructions are not very helpful either, typically something like (Whirlpool's):
    "Exhaust hood must be at least 12" (305 mm) from the ground or any object that may be in the path of the exhaust (such as flowers, rocks, or bushes, snow line, etc.). "
    Sep 2009
    Michael -- that's all I could find online. The AC manual's weren't much help either, they just said don't install with a dryer vent nearby. I was just wondering if there's a general rule of thumb out there??
    -Jon
    Jul 2011
    Central PA
    I've been looking for the same 'documentation' but it doesn't appear to be in the code. I use 4 or 5' as a recommendation. Maybe a good item to add to the IRC in the future? Anyone on the ICC here?
    BTW, year ago spring I had a call from a seller who thought they I had broken their AC.
    Ran out there in time to meet the service tech, who was just finishing cleaning the lint off the AC (problem was of course in the report) and informing the seller "Same problem as when I had to clean it off last time..."
    Robert Alfred Moller's Avatar
    Robert Alfred Moller Guest
    This comes from Whirlpools "Exhausting Dryer's Manuals"
    Exhausting a dryer near or next to an air conditioning or heat pump condensing unit should be avoided. The expelled lint can collect and clog the condenser fins and will likely require continual condenser cleaning. No mention of distance though.
    Knoxville, TN
    Here is a graphic that I use.
    Without getting into specific distances I simply write that the dryer vent is in close proximity to the condenser and may ...........
    And here I always thought the purpose of putting the a/c next to the dryer exhaust was to serve as a dryer booster fan ...
    Feb 2010
    Wenatchee Wa
    Jack, Thank you for the graphic.
    Don Hester
    NCW Home Inspections, LLC
    And if there is a secondary lint trap on the dryer exhaust?
    It would need cleaning.
