Results 1 to 28 of 28
    Sep 2008
    so so, California
    Default Need a name for this component.
    Just looking for the real name for this, I've heard it called a number of things but looking for its real or technical name.
    Raghav Singh's Avatar
    Raghav Singh Guest
    Default Re: Need a name for this component.
    Looks like a triangle duct board.
    Connecticut
    main trunk line
    What have you heard it called?
    Looks like ductboard to me...
    Aug 2008
    Atlanta, GA
    I refer to it as a "mixing box" for supply air.
    Sep 2008
    so so, California
    Wow...more names.
    I call it a plenum or plenum box
    I wasn't satisfied with any of the other names i have heard so I just fell back on this definition.
    Plenum:
    -An assembly or meeting with all members present.
    -A condition, space, or enclosure in which air or other gas is at a pressure greater than that of the outside atmosphere.
    Anyhow, It has worked so far with no complaints. I just didnt feel it was correct and dont want to look like a shmuck.
    "Sylvia"?
    Aug 2008
    Atlanta, GA
    I like Sylvia. Other posters were correct. Duct board triangle according to this supplier: American HVAC Parts: Ductboard Triangle
    Jun 2010
    West Chester PA
    An d the photo reveals what deficiency?
    Sep 2008
    so so, California
    Quote Originally Posted by Joseph Hagarty View Post
    Never implied there was..
    Sep 2008
    so so, California
    Quote Originally Posted by Hank Spinnler View Post
    What if it's square?
    Manifold
    Distribution box ... regardless of whether it is square, triangular, or some other shape.
    Sep 2008
    so so, California
    Thanks yall..
    Now I have 20 names for it.
    Thanks yall..
    Duct board Distribution Box
    Pheonix AZ air condition distribution box installation
    http://www.energy.wsu.edu/ftp-ep/pub...pt%20final.pdf (see Figure 3 on page 10 of 31)
    Also called plenum boxes and distribution plenums.
    David Bell's Avatar
    David Bell Guest
    A plenum
    Aug 2008
    Atlanta, GA
    So, will you call it Sylvia or by some other name?
    Lee Curtis's Avatar
    Lee Curtis Guest
    Plenum
    Jan 2011
    Marietta, Georgia
    My vote is for a distribution box; I use that term all the time. I use the term plenum for either the main starting point for the supplys or returns nearest the air handler. By the by, distribution boxes, at least around here, are not liked. Many a HVAC person has told me that they add a considerable amount of restriction to the system. It is like adding many,many feet to the duct run.
    Nov 2010
    Livermore, CA
    Hey Marc,
    I have always called them plenums. However, that is an interesting shape.
    Brian Handy / Sentinel Inspection Services
    Fuquay Varina, NC
    I use Plenum and or Distribute box. Who the hell came up with duct board, What is the word "board" meaning. Was it taken from using the bay area between joist boards as ducts......
    Mike Schulz License 393
    Affordable Home Inspections
    www.houseinspections.com
    Jan 2011
    Marietta, Georgia
    No, duct board is a material they make plenum boxes and distribution boxes out of. It's like a light weight material made from fiberglass that can be cut and moleded into shapes and gives a certain R value as well.
    Utah
    Assuming that the duct on one side is air from a blower and it enters the plenum for splitting to the other two ducts . . it is a "boom" box.
    AND as others have said it is high pressure drop, inefficient and the wrong type of duct tape is used. The tape used will deteriorate in about five years. It needs to be UL listed tape for duct seal and construction.
    Also it doesn't look like duct board to me, it looks more like Styrofoam, maybe fabricated out of a foam cooler. Duct Board will typically have a foil face and will often have markings on the exterior.
    Sean Meredith's Avatar
    Sean Meredith Guest
    Its a distribution box, mixing box made of duct board. Probably one of the worst materials to move air through the house. Havent these manufacturers ever heard of fibrosis???
    Utah
    Quote Originally Posted by Sean Meredith View Post
    If it is indeed duct board there is little cause for concern of fibrosis. Fiber duct and fiberglass duct liner have been used in duct systems for longer than I have been alive. They provide a good thermal barrier and are effective in noise attenuation.
    Properly installed they are a decent option to metal duct with liner.
    I am still not convinced it really is duct board though.
    The problem is it is a dust collector and it releases fibreglass. Many people do not want fibreglass lined ducting.
    Sean Meredith Guest
    With all due respect I am a insulator by trade. I insulate mechanical systems. Duct liners fail 99 percent of the time, over time. When this happens it releases fibers 100% of the time. The main reason for using duct board to move air in your house, is because its dirt cheap. Duct liners in large duct usually fail and they end up wrapping in duct wrap. The first thing I would do if I bought a new house would be to hire someone that doesn't deal with duct board.
