Results 1 to 3 of 3
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default AC refrigerant lines in plenum
    Can AC lines run through a supply duct.
    David Bell's Avatar
    David Bell Guest
    Default Re: AC refrigerant lines in plenum
    Whoever installed that "system" should be hung by his thumbs.
    Other than the missing trap, poor connections to the plenum, AC lines, missing secondary, crazy drain pan under the humidifier, and enough tape to build a bomb, I don't see a problem.
