    Kevin Luce's Avatar
    Kevin Luce Guest
    Default Clearance for an air conditioner
    I'm wondering if there have been any carrier unit that allow under 24 inch clearance from top of unit. My thinking is no. I did a search but no luck on Carrier units.
    Default Re: Clearance for an air conditioner
    My rule of thumb is 4 feet min., unless otherwise specified by manuf.
    Brian E Kelly's Avatar
    Brian E Kelly Guest
    Depending on the model the clearances are different. The York units have 2 clearances depending on the model. The min. height clearance is 48" and the other units have a 60" clearance. I imagine that Carrier might have the same situation.
    Peoria Arizona
    This Carrier unit calls for 48".
    http://www.docs.hvacpartners.com/idc/groups/public/documents/techlit/24aba-1si.pdf?SMSESSION=$SM$%2f0I2fGDwN1Zlj7kbsZLBul JkU7 rgN4715MJJQ%2f5bOUZaib5ISfLLSZud97Ep2%2flDLafmO0rd itJMoSG5wVnR23tedmJ3nGkE%2f9htGsLWvLTURlvnexNFXRu1 %2f1RUZtptHMBVshWYCTwLayREgs1nw9t0SvfxLRcX54%2bGgv nrJKTVnJburqdOB0iYBSK9%2b%2bwD26y5aBBLTs4%2feI09ib 5kI%2f1BA52h399g8QBrePd%2fMIyVXUn25vMcZx97PbJ0Ro9i UVqn452XBvzxJsn9p85uHcmRQyoANtqMb8AXkaD4Ipv2M4%2f9 1OocsH5Lb8zYOIT9307FpSU9HEw%3d
    Jeff Euriech
    Peoria Arizona
    Brian E Kelly Guest
    Jeff what are the letters and numbers after the .com???
    Brian, that is the full web address.
    Copy and paste the entire string into you address bar and it takes you to the pertinent information. I just tried it and it works for me.
    Jim
    STEP 3.—
    Clearance Requirements
    When installing, allow sufficient space for airflow clearance,
    wiring, refrigerant piping, and service. Allow 30--in. clearance to
    service end of unit and 48 in. above unit. For proper airflow, a
    6--in. clearance on 1 side of unit and 12 in. on all remaining sides
    must be maintained. Maintain a distance of 24 in. between units.
    Position so water, snow, or ice from roof or eaves cannot fall
    directly on unit.
    Jim
    Colorado Springs, CO
    You can make it easier for everyone by creating a link to the site like this:
    Carrier Installation Instructions
    To create a link simply type the following:
    {url= WEB SITE ADDRESS (e.g., www.inspectionnews.net) } WEB SITE NAME {/url}
    NOTE: Replace the { } brackets with [ ] brackets.
    Bruce Breedlove
    www.avaloninspection.com
