Thread: Clearance for an air conditioner
08-18-2007, 08:46 PM #1
I'm wondering if there have been any carrier unit that allow under 24 inch clearance from top of unit. My thinking is no. I did a search but no luck on Carrier units.
08-20-2007, 06:56 AM #2
Re: Clearance for an air conditioner
My rule of thumb is 4 feet min., unless otherwise specified by manuf.
08-20-2007, 08:52 AM #3
Depending on the model the clearances are different. The York units have 2 clearances depending on the model. The min. height clearance is 48" and the other units have a 60" clearance. I imagine that Carrier might have the same situation.
08-20-2007, 08:53 AM #4
This Carrier unit calls for 48".
http://www.docs.hvacpartners.com/idc/groups/public/documents/techlit/24aba-1si.pdf?SMSESSION=$SM$%2f0I2fGDwN1Zlj7kbsZLBul JkU7 rgN4715MJJQ%2f5bOUZaib5ISfLLSZud97Ep2%2flDLafmO0rd itJMoSG5wVnR23tedmJ3nGkE%2f9htGsLWvLTURlvnexNFXRu1 %2f1RUZtptHMBVshWYCTwLayREgs1nw9t0SvfxLRcX54%2bGgv nrJKTVnJburqdOB0iYBSK9%2b%2bwD26y5aBBLTs4%2feI09ib 5kI%2f1BA52h399g8QBrePd%2fMIyVXUn25vMcZx97PbJ0Ro9i UVqn452XBvzxJsn9p85uHcmRQyoANtqMb8AXkaD4Ipv2M4%2f9 1OocsH5Lb8zYOIT9307FpSU9HEw%3d
Jeff Euriech
Peoria Arizona
08-20-2007, 09:14 AM #5
Jeff what are the letters and numbers after the .com???
08-20-2007, 09:19 AM #6
Brian, that is the full web address.
Copy and paste the entire string into you address bar and it takes you to the pertinent information. I just tried it and it works for me.
Jim
08-20-2007, 09:21 AM #7
STEP 3.—Clearance Requirements
When installing, allow sufficient space for airflow clearance,
wiring, refrigerant piping, and service. Allow 30--in. clearance to
service end of unit and 48 in. above unit. For proper airflow, a
6--in. clearance on 1 side of unit and 12 in. on all remaining sides
must be maintained. Maintain a distance of 24 in. between units.
Position so water, snow, or ice from roof or eaves cannot fall
directly on unit.
Jim
08-20-2007, 10:41 AM #8
You can make it easier for everyone by creating a link to the site like this:
Carrier Installation Instructions
To create a link simply type the following:
{url= WEB SITE ADDRESS (e.g., www.inspectionnews.net) } WEB SITE NAME {/url}
NOTE: Replace the { } brackets with [ ] brackets.
Bruce Breedlove
www.avaloninspection.com
