Results 1 to 11 of 11
    Default Who needs combustion air?
    As I keep telling clients, I see something new at every inspection.
    Sep 2010
    Vancouver
    Default Re: Who needs combustion air?
    That's a great filter did you tell them to change it often. It's funny when installing these systems they can get away with such issues. Look at this furnace I just saw.
    Jul 2010
    Kansas City Missouri
    Quote Originally Posted by Paul Sew View Post
    At least they used the metal dryer vent rather than the vinyl type. Also changing the filter will be easy.
    Galen L. Beasley
    Inspections Supervisor
    Housing Authority of Kansas City MO
    Aug 2010
    BC Canada
    Also, is it ok the vent to masonry chimney? A wood burning or gas burning fireplace?
    Sep 2010
    Vancouver
    Quote Originally Posted by Peter Louis View Post
    Fine to vent through the chimney, but the issue is improper material used to vent from the furnace. It was a very shady job on the furnace with the supply plenum cut off and funky vents all over the basement for heat. The chimney was also a good clue for an oil tank.
    Chicago
    Was the vent just some Class 0 flexible duct or was it a Metal-Fab B-vent?
    http://www.mtlfab.com/media/L1940.pdf
    Corey
    Sep 2010
    Vancouver
    Quote Originally Posted by Corey Friedman View Post
    Corey
    Corey, thanks for the insight of that bvent material, I'll have to go back and have a closer look. It does look like that flex b-vent.
    Bradley Illinois
    It is not okay to vent an 80% furnace to a masonry chimney unless it has a metal liner according to most manufacturers because of the cooling and condensation issues
    Richard Johnson's Avatar
    Richard Johnson Guest
    Quote Originally Posted by Steve Duchene View Post
    The primary reason for this is that when the chimneys were designed, the gas appliances connected had standing pilots which constantly provided minimal heat source to the chimney keeping it warm allowing good draft. When you remove a standing pilot device and install an intermittent pilot device, the chimney cools during the off cycle. When the device then starts its cycle, the combustion gasses cool in the chimney preventing proper draft.
    Binford Tools's Avatar
    Binford Tools Guest
    Dang that's down right scary. Not enough air would mean incomplete burn which could crate very high CO.
    Here they require a 90 ell on the intake to prevent something from accidentally falling and restricting the intake. But in this case the HO might have still stuff a rag in it
    Are you sure that's a rag? It looks like religious head gear to me.
