Results 1 to 3 of 3
    Daniel Island, SC.
    Default Geothermal System
    Hello,
    Can anyone tell me what the range of acceptable differentials between output and return should be on a Geothermal Packaged heat pump?
    Jim
    Bob Cone's Avatar
    Bob Cone Guest
    Default Re: Geothermal System
    Air or water temperatures?
    I can only give you the readings from my geothermal heat pump.
    Climate Master
    Tranquility 27 TT Series (2 stage scroll compressor)
    10 KW electric back up
    4.5 ton
    superdeheater
    Horizontal loop
    Water temp of incoming 58.5F
    Water temp of outgoing 53.6F
    Return air temp - 71.1
    Supply temp. 97.2
    +26.1 difference
    These readings were taken Sept 29/10
    This is also a great site for geothermal systems.
    Geothermal Heat Pump Forum
