Thread: Funny Noises
    Connecticut
    Default Funny Noises
    Not so funny really.
    1986 Weil MClain gas fired boiler
    Started her up and everything normal.
    When it reached temp, it started making sound like water dripping onto the burner tube.
    The sound would continue for a short while after the unit shut down, still with no water evidence.
    I layed on the floor for a few minutes and watched and saw no overspray or water dripping.
    I did get a gas smell at times when i retuned to the boiler room to check again.
    So, i'm stumped, water or gas problem.
    Anyone ever experience anything like this?
    I never heard a boiler do this before
    Default Re: Funny Noises
    The sound would continue for a short while after the unit shut down, still with no water evidence./
    My Swag,
    Leaking High Pressure relief valve.
    * did the system have anti-freeze in it.
    ** Weil MClain is adamantly against adding AF to their closed loop system.
    Could be condensation.
    Happens on gas WH on start up.
    Connecticut
    Billy, Yeah, that's what i am leaning towards, along with the gas smell.
    Not condensation. I ran the piss out of that thing for 3 hours
    Big house
    But I,m out of it now.
    The thing was 26 yrs old anyway
    David Bell's Avatar
    David Bell Guest
    Small crack or leak between sections. You didn't mention if it was a cold start boiler.
    David Bell's Avatar
    David Bell Guest
    Might also check for a clogged flue or chimney. I have found everything from birds to brick pieces on top of boilers. The built up flue gasses could condensate.
    Connecticut
    COld start
