    Jul 2010
    NC
    Default Age of Nordyne split system heat pump
    hello,
    Can any of you fellow inspectors help me get the age of a Nordyne split system heat pump. Air handler serial number is GBD100307719; Heat pump serial number is: JTF100400633
    Thanks in advance
    Sidney Alstad
    Default Re: Age of Nordyne split system heat pump
    March and April 2010 I believe.
    John,
    How did you determine age?
    John,
    First two numbers are the year, second two are the month. I didn't have this memorized for Nordyne - I looked it up.
    Bob Cone's Avatar
    Bob Cone Guest
    I believe the first two numerals are the year and the next two numerals are the month:
    GBD10 (2010) - 03 (March)-07719
