Results 1 to 18 of 18
    Mar 2011
    Lombard, Illinois
    Default Help writing up a chimney
    When you see this metal chimney (SEE PICTURES)What's the best way of writing it up. Any help would be great.
    Thank you.
    Fidel F. Gonzales
    RELIANT INSPECTION SERVICE
    http://www.reliant-corp.com
    Default Re: Help writing up a chimney
    Say what you see.
    Chimney is rusted and is at the end of its useful life.
    Expect to replace chimney in near future.
    Mar 2011
    Lombard, Illinois
    Say what you see.
    Thanks Garry. Just wanted to reported correctly...
    Have a super day..
    Fidel F. Gonzales
    Orlando, FL
    Is that just metal siding or a pre-fab part?
    Mar 2011
    Lombard, Illinois
    Yea, Just the rust on the outside. The inside was fine.
    Fidel F. Gonzales
    My own approach would be more specific by writing that the "vent housing" is rusted. I use the word "chimney" when it's a structure such as brick or wood framed. People will understand either way though.
    A chase is not a chimney.
    A metal "pot", termination, cap or shroud atop a chase, is not a chimney.
    Mar 2011
    Lombard, Illinois
    Thanks Eric, I will take your advise and do this from now on. Thank you for replying. Best regards. Fidel
    Fidel F. Gonzales
    Mar 2011
    Lombard, Illinois
    Thank you for the clarification. Most appreciated.
    regards. From Chicago
    Fidel F. Gonzales
    Sep 2008
    so so, California
    Quote Originally Posted by fidel gonzales View Post
    Thank you.
    Is that a clay (or other) liner terminating 3-4" from the bottom of the chim cap?
    Mar 2011
    Lombard, Illinois
    Its all metal
    Fidel F. Gonzales
    Sep 2008
    so so, California
    square metal flue?
    Mar 2011
    Lombard, Illinois
    square metal flue?
    Round metal flue
    Fidel F. Gonzales
    Cool Re: Help writing up a factory chimney
    Appears to have an unlisted masonry-style chimney termination over the factory built chimney, which would not be approved. Recommend qualified chimney inspector conduct a Level II inspection to identify the chimney manufacturer and model then identify the installed components and advise on suitability for this application.
    What is connected to this chimney? Oil heat? Factory built woodburning fireplace? Woodstove? What about the inside and rest of the installation? Did you/ can you pull this termination to inspect the flue for signs of damage, obstruction or modification?
    Regardless, there is corrosion that needs to be addressed.
    Sep 2008
    so so, California
    Default Re: Help writing up a factory chimney
    What he said...
    Mar 2012
    Michigan
    Corrosion of metal will make its surface porous and may allow water to "wick" to other materials creating more damage. Depending on materials used, certain metals will act as an anode with others increasing deterioration. It is nearly incapable of perform the protection it was originally intended for.
    These housings are very common around here but they're getting old and deteriorated. They're wonderful for the birds and their nests. That cap in Fidel's photo is a retrofit - either because there was rust through or bird problems.
    Mar 2011
    Lombard, Illinois
    Hi Marc, Did make a recommendation to have it inspected by chimney company. as far as what is connected to; just to the furnace
    and water heater. As far a this unit it's A metal "pot" not a chimney.
    Thanks to all that responded.
    Fidel F. Gonzales
