Thread: Water Heater Vent
11-20-2012, 03:09 PM #1
Water Heater Vent
Hi All,
Saw this vent for a water heater and it look ok to me. However ,I’ve neverseen this type of arrangement for awater heater. I wanted to wait before I passed judgment on whether this is anOK arrangement. I would really appreciate input from the group. See the pics the Inlet has the following info ANS-721-12A 1977 that can't be seen in the picture
Thank so much
Similar Threads:Last edited by Fidel Gonzales; 11-20-2012 at 04:34 PM.
11-20-2012, 07:20 PM #2
Re: Water Heater Vent
Wow-- never seen that arrangement before. It's got the required draft diverter in the same room as the water heater, so I don't know for sure if that is wrong. What do the manufacturer's installation instructions say?
11-20-2012, 07:57 PM #3
No, not okay. Need lowboy or shorter WH in low ceiling height uninsulated half-basement or crawl space. Top 18" clearance unprotected ceiling/floor assembly.Double action baro damp and safety interlock from b-vent not single wall with *foil?* "shield" on lateral section in unconditioned short height half-basement or crawl adjacent to steel I-beam mid span support. Breaching wrong too, chimney should be lined and marked. Looks possible of the vintage home which may have originally had coal fired furnace & unlined (or poss. tiled) chimney for same...is this a mid-to-late 40s split level?
11-20-2012, 09:21 PM #4
No manufacture instruction. The home is a 1901 Victorian. With a basement. It also has a modern boiler for heat. Thanks to you both for responding
