Results 1 to 10 of 10
12-05-2012, 02:13 PM #1
aux pan for attic condensate pump
I have to get my hearing checked. I could have sworn the buyer said that the seller was a HVAC contractor...
12-05-2012, 02:46 PM #2
Re: aux pan for attic condensate pump
Deal killer....
12-06-2012, 05:26 PM #3
Picky HI
approved galvanized drain pan
approved aluminum baking sheet
same difference ... its not like the condensate water will be hot
12-07-2012, 06:11 AM #4
More than condensate would have hit the pan if he were to have used his wife's good roasting pan.
Apollo Home Inspection
St. George UT
12-07-2012, 06:37 AM #5
Kudos for utilization of the available materials and saved the gas, time, money and the earth by not having to make another trip to the supply store.
12-07-2012, 06:43 AM #6
Kind of a smart way to take care of a possible problem... I not 100% sure but I do not think the condensation pump is required to be in a pan. I'll need to look that one up...
I see condensation pumps all the time most in my area have an emergency cutoff float switch installed in them that detect high water or if the unit fails.
12-07-2012, 07:44 AM #7
I think you heard him right, probably is a HVAC contractor…
Just like the Plumbers house with a missing sink…
The Builders home with half the cabinets installed…
And, the Electricians home with light fixtures hanging from the wires…
12-07-2012, 08:08 AM #8
12-07-2012, 08:58 AM #9
12-07-2012, 12:19 PM #10
