Results 1 to 12 of 12
Thread: Whole house ventilation system
01-09-2013, 07:57 PM #1
Home was built in 1994, has a whole house ventillation system that's connected to the HVAC ductwork. I have never seen one with an air intake vent installed in the crawlspace. This just looks bad, drawing musty air from crawlspace into the home. I am guessing that the vent was intended to be routed outdoors.
01-09-2013, 08:36 PM #2
Re: Whole house ventilation system
01-09-2013, 08:47 PM #3
No it's not a sealed crawlspace. Standard vented crawl.
01-10-2013, 04:59 AM #4
Looks like a motorized damper which has not been wired in, which means its not functioning as per intended use.
01-10-2013, 06:30 AM #5
Looks like it could be a dump damper that would tie into the zone panel.
01-10-2013, 06:31 AM #6
We don't have contraptions like that around here, but,in general, mixing crawlspace air into the home air seems like a really bad idea for several reasons.
01-10-2013, 05:04 PM #7
Agreed ... it is a really, really, really stupid idea to take air from the crawlspace and suck it up into the living space ... unless the crawlspace was lined and being used as a return air plenum (which is still not real smart), and in which case it would not be 'fresh air' anyway.
01-10-2013, 05:31 PM #8
Yes it's definitely not a good idea to pull air from crawlsapce into the home. I am recommending an HVAC contractor evaluate and repair. The damper was connected to low voltage wire. I see these types of air exchange systems installed in homes built in the early 90's. Typically the electronic damper is connected to an exterior vent.
01-10-2013, 06:34 PM #9
Not meaning to insult your intelligence, but are you sure it was on the air return and not the supply?
I could see having a supply duct ala' Dr. Joe in a conditioned crawl space.
01-10-2013, 08:00 PM #10
01-11-2013, 01:03 PM #11
01-11-2013, 08:48 PM #12
Temporary since '94, yeah, right.
Most people are pretty clueless when it comes to HRV systems. I find them turned off more often than not and the intakes are stuffed full of sticks and leaves.
I rarely find them in the new houses. It was like a passing fad in this climate. We can just open a window to get fresh air, why not, eh?
