    Jul 2009
    Spokane, WA
    Default Code for vent pipe slope
    Believe it or not the seller says she will fix a negative sloping furnace vent pipe connector only if I can provide the code for it. I do not recite codes in my reports but use diagrams to illustrate the 1/4 inch per foot slope upward away from the furnace. I'm sure someone here knows it off the top of their head. Thanks for the help.
    Apr 2011
    Bozeman, Montana
    Default Re: Code for vent pipe slope
    Quote Originally Posted by Bill Anglin View Post
    IRC
    G2427.10.8 (503.10.8) Slope. A vent connector shall be installed without dips or sags and shall slope upward toward the vent or chimney at least 1/4 inch per foot (21 mm/m).
    Exception: Vent connectors attached to a mechanical draft system installed in accordance with the appliance and draft system manufacturers’ instructions.
    Chicago
    IRC M1803.3 ...Connectors shall be as short and straight as
    possible and installed with a slope of not less than 1/4 inch (6 mm)
    rise per foot of run....
    Mike Lamb
    Inspection Connection, Inc.
    Jul 2009
    Spokane, WA
    Thanks again
