Results 1 to 12 of 12
    Andy Murdock's Avatar
    Andy Murdock Guest
    Default Age of Climate Master Geothermal
    I finally found one I can't solve! This doesn't add up....
    House built 2000
    But HWH is 2004
    Climate Master Heat Pump
    S# B10483591
    Coils rusty. Looks more like 8-13 years
    Digest says 1st letter is month, second two are year. No way this is 2010.
    Any similar experience? Suggestions?
    Thanks,,
    Andy
    Default Re: Age of Climate Master Geothermal
    I have a Climatemaster Geo Thermal Heat Pump
    My unit serial no. is: L13781102. It was installed Oct 2008.
    Your unit S# B10483591
    I think you have a unit manufactured sometime in 2004 or 2003?
    manufacture or age of an CLIMATE MASTER® furnace or other CLIMATE MASTER® HVAC units | Building Intelligence Center
    Was there a former heating unit that was replaced in 2004 with this unit?
    Andy Murdock Guest
    No. Geothermal installed in new construction.
    I think the guy was doing bits and pieces as he got the money.
    I'm wondering if he didn't start permit in 2000 and finish in 2004!
    AM
    David Brodrecht's Avatar
    David Brodrecht Guest
    The link attached is incorrect for a serial number of this type. Starting in 1999, ClimateMaster uses the first letter to refer to the year: B = 2000. The next number is almost always 1 (probably an internal reference for CM), then the next two numbers refer to the week. Not all letters are used, hence L refers to 2008.
    B10483591 was built in the fourth week of 2000.
    Thanks David.
    Aug 2012
    Alabama
    Quote Originally Posted by David Brodrecht View Post
    So if B=2000 and L=2008 what does J equate to? I've got a unit with SN J15144169. So it's the 15 week of year J, I just don't know what year J represents. Thanks.
    Go here: Building Intelligence Center | Your #1 resource for determing the date of manufacture or age of HVAC & Water Heater equipment.
    Click on HVAC Production Date/Age in left column
    Click on Climate Master in the list (you should be here: manufacture or age of an CLIMATE MASTER® furnace or other CLIMATE MASTER® HVAC units | Building Intelligence Center )
    The examples don't quite match the dates of construction or the water heater date ... unless ... unless we do what Dave said and ignore the first '1' digit after the number, then it matches the water heater date as the date would be: B10483591 or February of 2004.
    If you ignored the first '1' in the example on that website, the date of manufacturer would not be affected because K111 would still be October of 2011.
    Just sayin' ... it works out if that is done.
    Mar 2012
    Lansdale, PA
    So Raymond's would be ? Maybe you skip the first two numbers, then Raymond's would be 2007 and the OPs 2004. Or maybe for some reason Raymond has a 2003 model and the OP was a 2000 model (using the second number. I'm just guessing because I never see this brand.
    I suspect that Raymond's unit follows the Style 3 serial example - not sure what letters between E and N represent which year, but his L number fits between the two example letters shown (E=2003 and N=2010, Raymond's L=2007/2008 so it fits between the two shown).
    Mar 2012
    Lansdale, PA
    O.K. I'll buy that. Then going back to an earlier post, if they started using that style in 1999, A=99, B=2000, and so on. If you delete the G because it can look like a 6 and the I because it can look like a 1, all the letters and numbers would match up.
    Many skip I and J because those two can be confused, Q is also skipped because it looks like O, and some skip O (as in M-N-O-P) because it can be confused with 0 (as in 0-1-2-3).
    If they skipped I, J, and Q, then the list would be:
    A=1999
    B=2000
    C=2001
    D=2002
    E=2003 (which is shown in Style 3)
    F=2004
    G=2005
    H=2006
    I=(usually skipped)
    J=(usually skipped)
    K=2007
    L=2008 (Raymond's)
    M=2009
    N=2010 (which is shown in Style 3)
    O=(frequently skipped)
    P=2011? (2012 if O is not skipped)
    Q=(usually skipped)
    R=2012?
    S=2013?
    Just guessing ...
    Mar 2012
    Lansdale, PA
    A=1999
    B=2000
    C=2001
    D=2002
    F=2004
    G=2005
    H=2006
    I=(usually skipped)
    J=(usually skipped)
    K=2007
    L=2008 (Raymond's)
    M=2009
    Q=(usually skipped)
    R=2012?
    S=2013?
    Just guessing ...
    I think this is close, but today I learned that J is 2006, and I saw a Q today, which was recently installed. Odd that they would use Q.
