Results 1 to 3 of 3
    Brian Harwood's Avatar
    Brian Harwood Guest
    Default Carrier Heat Pump Decoding
    Can anyone advise the size of the following 1998 Carrier heat pump: Model-50ZH--036--301, SN-3798G42150?
    c francis's Avatar
    c francis Guest
    Default Re: Carrier Heat Pump Decoding
    Not sure, new to this, but I would think that the 36 in the model number would ref to btu making it a 3 tonne... Unit bow many pumps on flow centre?
    Sep 2007
    Fort Worth Texas
    Quote Originally Posted by Brian Harwood View Post
    Should be a 3 ton system
    12 btu per ton 36/12=3 tons
    Year should be numbers before the middle letter on Carrier systems = 1998
