Results 1 to 2 of 2
    Mar 2009
    Charlottesville, Va.
    Default Whirlpool Heat Pump Date Code Help
    Whirlpool heat pumps are not in the usual data base I use. Can someone please
    help me with deciphering these.
    Outdoor coil 1603G40400
    Air Handler 6005E46764
    Thank you
    Mar 2012
    Lansdale, PA
    Default Re: Whirlpool Heat Pump Date Code Help
    Quote Originally Posted by Robert Foster View Post
    Thank you
    It would help if you have a rough idea of the age. I am not familiar with that number series, but as a guess it could be 2004 based upon the 4 in each number after the letter. Since 2003 Lennox has produced equipment under the Whirlpool name for Tradewinds Distribution LLC, a subsidiary of Watsco Inc. I believe that Heil-Quaker stopped using the Whirlpool name in 1987. I'm not sure if it was used between those dates.
