Results 1 to 3 of 3
Thread: Coleman Forced Air Furnace Age
05-16-2013, 07:18 PM #1
I have scoured my resources and can not find a resource for the age of this furnace. The model number is 2636A and a series number of 856. I could not find a serial number on the plate. Any ideas? I was told the furnace was original to the house. Thanks for your help.
05-17-2013, 10:55 AM #2
Re: Coleman Forced Air Furnace Age
Coleman Heating and Cooling was bought by Evcon Industries in 1990 and by York (owned by Johnson Controls) in 1996 - York has manufactured under the Coleman name since 1999. You might try contacting them at: Coleman Heating & Air Conditioning, 5005 York Dr., Norman, OK 73069, 877-874-7378.
Is this a manufactured home? The complete model and serial number should be in two boxes on the same line on the data tag. See: manufacture or age of an COLEMAN® furnace or other manufactured COLEMAN® HVAC unit. Sometimes the numbers can be hard to read. For example - is the 1st number in your model a "2" or a "7?" Coleman did produce several series 856 furnaces, but I can't find any 2600 model numbers. You may also be able to get a date code from the furnace control board.
05-24-2013, 01:49 PM #3
You did not give the age of the house. The series number is not the serial number. Below are some key dates for Coleman.
1958-Coleman Company entered the Heating and Air Conditioning business with units designed for mobile homes;
1984-acquied Red T Coil, a mfg. of evaporator coils and fan coil units;
1990-Beacon Capital Corporation acquired Coleman’s Heating and Air Conditioning division to create Evcon Industries;
1996-York acquired Evcon Industries-continued to market their products under the Coleman-Evcon name;
1999-began marketing products solely under the Coleman name
