Thread: Magic Heat
04-06-2007, 06:22 AM #1
Magic Heat
Found this on an inspection yesterday attached to oil fired boiler vent installed before the barometric damper. The Boiler is approx. 40 years old. The Magis Heat unit runs on 110v. Has any one ever seen this before?
04-06-2007, 07:05 AM #2
Re: Magic Heat
Ive not seen that exact unit before but it appears to be a secondary heat exchanger that captures some of the flue gas heat and delivers it to the space. As long as it does not take too much heat out of the flue gas it should not cause a condensation problem within the flue.
I presume the 110v runs a small fan in the unit?
04-06-2007, 02:23 PM #3
Re: Magic Heat
List for $228.49 and still being sold:
"Designed for use with all types of heating equipment with inside flue temperatures exceeding 350F, skin temperatures of 250F
Installs easily using basic household tools.
Thermostatically controlled; factory preset to provide troublefree operation.
Plugs into an standard 110v home outlet.
Unit size 14 3/4" H x 10 3/4" Wx 14" D
Crimp is on the bottom."
Yes, they cause a lot of condensation . Available in 6" & 8" diameters.
Bob
04-06-2007, 05:06 PM #4
