    May 2009
    Washington State
    Mar 2012
    Lansdale, PA
    Default Re: Gas Line in Contact with Furnace Flue
    Quote Originally Posted by Jim Hintz View Post
    Not much different than a gas line in a gas fireplace. I can't recall any clearance requirement in codes. I would say the chance of explosion is zero, but I am willing to stand corrected if someone knows otherwise.
    Connecticut
    If that plastic can melt, it's a fire hazard. Can it melt? I would recommend double walled vent pipe for safety.
    Mar 2008
    Charlotte NC
    Already has all those wrinkles of double wall B' vent.
    Mar 2012
    Lansdale, PA
    That is not b-vent. It is single wall.
    The gas connector has a polymer coating (looks like BrassCraft). These can be used inside of a gas fireplace so I don't think melting is likely.
    May 2012
    eastpoint fl
    Not sure what plastic you are referring to. If it's the yellow gas line, I think that is coated stainless steel.
