    william siegel's Avatar
    william siegel Guest
    Default Painted Air handler coils
    Why would anyone paint the air handler coils? 2006 townhome. No evidence of Chinese Drywall anywhere in the unit. These coils look to be original. The copper portion they did not paint was not tarnished.
    New York
    Default Re: Painted Air handler coils
    ... lipstick on a pig.
    homeinspectionsnewyork.com
    eifsinspectionsnewyork.com
    Maybe it was cooling too well and instead of thinking of turning the thermostat down they lowered the amount of heat transfer the coil will provide?
    While that may seem dumb on the surface, it would take a smart person to think of lower the heat transfer by painting the coil ...
    Quote Originally Posted by william siegel View Post
    Less-than-professional smoke/fire remediation or water/mould remediation (or REO/flipper) painting crew perhaps. Any clues behind insulation, behind register covers, outlet plates, attic, removable window sashes, etc.? Checking call reports (F.D. & P.D.), permits & CLUE Reports by the interested contract purchaser might be a good idea.
    Painted to hide RUST or slow down the oxidation/rusting. They were after the steel and were carried away in a beautification process. Enlarge the pict and look at lower half of picture.
    Don't think it was to put something over on anyone. Just an attempt to get a little more time out the equipment.
    Utah
    I noticed you are in FLA. Near the coast?
    Sometimes a coating is applied to coils to protect from salt in the air. Does it appear to be done by a DIY'er or is it factory?
    Unfortunately we will never know the answer. This was a foreclosure.
    St. Louis, Mo. area.
    Quote Originally Posted by Rod Butler View Post
    Looks awfully sloppy for OEM work. My guess is that it was done by the same person that put all the heavy grease on the garage's overhead door guide rails.
Tags for this Thread
