Thread: Boiler advice needed
02-14-2014, 08:17 AM #1
I have a 30+ year old Weil Mclain boiler. This morning I noticed no heat, so took a look and found a couple pieces of insulation had fallen onto the standing pilot which was out. I removed the insulation and fired the boiler back up no problem.
The insulation pieces are about 3/8 inch thick and together are about 40 square inches or so. Clearly I'm going to be in the market for a new boiler, but we're still paralyzed by snow so I don't think that's going to happen anytime real soon.
My question regards the purpose of the insulation. Is it mainly to reduce heat loss, or does it prevent the boiler cabinet from melting down? In other words, can I limp along for a bit with reduced efficiency, or would I be inviting a catastrophe?
Thanks!
02-14-2014, 08:31 AM #2
Re: Boiler advice needed
3/8" thick is likely not doing much to insulate. Likely okay without it given its thickness.
02-14-2014, 09:21 AM #3
02-14-2014, 03:48 PM #4
02-14-2014, 10:30 PM #5
02-17-2014, 08:33 AM #6
A picture would be helpful. In the end, if there is a critical function for the insulation, you have probably found out by now, or will soon enough.
Randall Aldering GHI BAOM MSM
Housesmithe Inspection
www.housesmithe.com
02-17-2014, 05:32 PM #7
If the insulation is from the plate that covers the access to the burners, then not an issue not to replace. Just remember the metal plate may be hot when you go to remove it to access burners.
