Results 1 to 13 of 13
Thread: HRV hook up
07-14-2014, 07:22 AM #1
HRV hook up
This was not an actual inspection, but I noticed this in a home a few days ago (see pictures).
It appears to me that this configuration was incorrect: the two un-insulated connectors are connected to the same return plenum, while the insulated ones are terminated outdoors.
Mike Rodney
Ontario, Canada
07-14-2014, 08:06 AM #2
Re: HRV hook up
07-14-2014, 08:32 AM #3
Re: HRV hook up
Yes but are they supposed to be connected to the same return plenum...about 10 feet apart?
Mike Rodney
Ontario, Canada
07-14-2014, 05:48 PM #4
Re: HRV hook up
Here is a diagram that might be useful. Of course with this setup, the HRV fan would have to overcome the static pressure of the furnace fan during furnace operation.
Your setup basically appears to short cycle the air without doing much good.hrvImage.jpg
07-14-2014, 06:09 PM #5
Re: HRV hook up
The installer thought he would pull some stale air from the furnace return and replace it with fresh, maybe? So somebody ended up paying out a buch of money for something that does a little bit of good maybe on a good day. When the furnace is shut down, it will be a useless waste of electricity. Maybe with a constant flow it will work a bit.
HRV works best with returns and intakes completely separate from the furnace ducts, IMO, AFAIK.
07-14-2014, 07:03 PM #6
Re: HRV hook up
That is one of three recommended installation methods recommended by manufacturers.
Simplified Volume Ventilation
http://www.venmar.ca/DATA/DOCUMENT/1...ES_HRV_ERV.pdf
07-14-2014, 07:45 PM #7
Re: HRV hook up
BTW how old is this furnace installation? If its newer the air intake and exhaust for the furnace is now required to be PVC piping and not ABS. But this is why I am asking as to the age of the home/furnace.
07-15-2014, 05:29 AM #8
07-15-2014, 05:36 AM #9
Re: HRV hook up
Okay if thats the age then ABS was the standard. If memory serves me correctly ABS was discontinued for use on furnace 3-4 years ago and new installations or upgrades must now be PVC.
07-16-2014, 06:07 AM #10
Re: HRV hook up
636 required on all new installations starting August 1, 2007
Bryce Jeffrey
Jeffrey Home Inspection
St. Thomas, Ontario, Canada
07-16-2014, 09:31 AM #11
Re: HRV hook up
Thanks, Raymond. I've never seen it done that way.
(For homes with forced air heating. See illustration at right.)Fresh air and exhaust air flow through the furnace ducts, which simplifies the
installation.
The use of bathroom fans and a range hood is suggested to exhaust stale air.
NOTE: For this type of installation, the
furnace blower must be running
when the unit is in operation.
If using Method 2, make sure the furnace blower operation is synchronized with the unit operation!
See Section 5
07-16-2014, 06:25 PM #12
Re: HRV hook up
07-17-2014, 04:09 PM #13
Re: HRV hook up
