Results 1 to 3 of 3
Thread: Furnace Flex Line
07-17-2014, 05:25 AM #1
Furnace Flex Line
I always call out flexible gas lines passing through the furnace wall ( the usual warning about the sheet metal cutting through the flex due to vibration etc...). Wednesday I saw something new. About a 1/8 inch thick rubber grommet/feed through between the flex line and the furnace sheet metal. Does this make it O.K.? I thought that the gas line had to be hard pipe to the interior of the furnace.
The seller has had annual maintenance done by a good local HVAC company and the furnace is a Lennox. No comments from the furnace experts. I hate to make this an issue if it is just something that I have been previously unaware of.
07-17-2014, 07:18 AM #2
Re: Furnace Flex Line
Somewhere I read that gromit is acceptable, and have always recommend iron pipe or gromit.
07-17-2014, 10:26 AM #3
The grommet would protect the pipe from the sharp edges.
