Results 1 to 12 of 12
Thread: water heater vent clearence
09-03-2014, 04:19 PM #1
09-03-2014, 04:49 PM #2
09-03-2014, 06:41 PM #3
09-03-2014, 07:07 PM #4
Re: water heater vent clearence
Did you look up the specs for the vent clearances to a window from Rinnai? They are sometimes much closer than you think they should be. Is that where you got the 48" from?
09-03-2014, 07:15 PM #5
09-03-2014, 08:29 PM #6
Search for that model Rinnai manual and look it up in the installation instructions. I think it is 36" in Canada, but 12" is good enough for you'all.
http://www.rinnai.us/documentation/d...7-077x0101.pdf
Page 26. It is 12" in the USA.
09-03-2014, 10:01 PM #7
09-04-2014, 10:52 AM #8
09-04-2014, 11:24 AM #9
09-04-2014, 03:09 PM #10
09-05-2014, 07:52 AM #11
Dont forget slope of vent...check for passive condensate drain if required..
Mazza Inspections and stuff...
https://mazzainspections.com
https://waterintrusionspecialist.com
10-02-2014, 11:02 AM #12
refer to manufacturer which likely requires minimum of 4 ft to operated window remember one is intake and one is exhaust that likely can be added to to force adequate clearance Also expect for Navien gas line must be 3/4 and gas line should have a sediment trap
- - - Updated - - -
