Results 1 to 13 of 13
04-09-2015, 01:28 PM #1
strange marks on boiler outlet pipes
guys
have never seen these marks on copper pipes before. this is a five zone boiler system. the little silver dots seemed to be pitted. any clues
cvf
04-09-2015, 02:19 PM #2
Re: strange marks on boiler outlet pipes
Originally Posted by CHARLIE VAN FLEET
That is a huge problem with copper over on the west coast of Florida, especially in the Tampa Bay area and sorrounding areas.
04-09-2015, 08:09 PM #3
04-10-2015, 03:59 AM #4
04-10-2015, 05:06 AM #5
04-10-2015, 07:19 AM #6
The problem on the west coast of Florida in the Tampa area is phosphate (as I understand it).
That part of Florida has a lot of large phosphate mines, because the soil contains so much phosphate, thus the phosphate level in the ground water and drinking water is high and the high level of phosphates is what corrodes the inside of the copper pipes.
That said, I agree with Bryce, that video contains very good information ...
(including the part of the video saying that it can a water quality issue affecting an entire area).
I knew about the anode rod issue and its short life, but not of the affects on the copper piping once the anode rod is gone and the water starts attacking the tank - got to think outside the box ... er ... outside the water heater.
04-11-2015, 09:13 AM #7
Reverse Osmosis water treatment causes pin hole leaks in Florida.
http://www.cityofmarcoisland.com/mod...ocumentid=1464
PROFESSIONAL CONSULTING AND INSPECTION COMPANY INCLUDING FORENSIC INVESTIGATIONS
http://jeffghooper.com/
04-11-2015, 03:17 PM #8
04-11-2015, 05:43 PM #9
Maybe I missed it but where does it say RO causes pin hole leaks?
Addendum
Chloramines causing pin hole leaks -
http://www.google.ca/url?sa=t&rct=j&...90491159,d.cWc
04-11-2015, 07:20 PM #10
RO causes also, that is our Florida issue.
Residential RO Systems
04-12-2015, 03:18 AM #11
Thanks Jeff,
After I asked the question I did some more research and found other documents which pertain to RO and copper. But it seems other factors do play into the problem of leaks.
However, I am wondering if this is the cause in the photos provided by Charlie, since this is a closed system. A one time filling of the piping and boiler is not being flushed daily as would the potable water supply. I am thinking that this damage may be the result of a cast iron boiler wherein iron fragments from installation caused the deterioration? And whether the copper is L or M type?
Nor did Charlie mention anything about the boiler or age.
04-12-2015, 06:48 AM #12
04-12-2015, 06:16 PM #13
1979 BURNHAM
- - - Updated - - -
1979 BURNHAM
