Results 1 to 3 of 3
    Iron Mountain, MI
    Default Dual Zone Furnace
    A furnace with two t-stats (one for the main level, and one for the lower level).
    When the t-stat is turned up for the main level the furnace operates. When the t-stat is turned up for the lower level the furnace does not kick on.
    What can be some of the reasons be for this?
    Thanks,
    Joe
    Mar 2012
    Lansdale, PA
    Default Re: Dual Zone Furnace
    I am assuming that this is a zoned system. Did you see zone dampers? If so it could be a problem with the zone controls or the T-stat.
    I sometimes see systems with a thermostat on the first and second floor, but it is not a zoned system. With this setup the second floor T-stat controls AC and the first control heat.
    Aug 2011
    Recently, I was in a house with two thermostats, but one didn't do anything. After a little investigation, I realized that one wasn't wired to the furnace. Apparently the owners would rather have a dead thermostat on the wall than repair a hole in the wall.
    If the furnace isn't zoned, then you may have a similar situation.
