Thread: tankless water heater
07-02-2015, 06:38 PM #1
I inspected a home today that was extensively remodeled in 2013, with permits/inspections (I know- so what?). There is a Rheem 180,000 Btu tankless wh in a small laundry room. There was no combustion air, and the vent pipe is touching the wood ceiling. Is there a combo combustion/exhaust vent for tankless water heaters, and if so is it zero clearance to wood? Roof was not walkable, forgot to take a closer look at the vent pipe above the roof but it looked like a normal vent pipe. Second question- 3/4" pipe from home to water heater. But there is several feet of 1/2 inch flexible copper pipe at the propane tank. Is this allowed, or does it have to be 3/4" pipe all the way to the tank. I'm going to check Rheem website after I finish the report. but figured I'd get better (and easier) info here.
Similar Threads:I have not failed. I've just found 10,000 ways that won't work. (Thomas Edison)
07-02-2015, 08:09 PM #2
Re: tankless water heater
Randy, I'm pretty sure that unit is sold only by Home Depot.. I have come across the exact same unit before. It uses a concentric vent pipe(pulls in combustion air and exhaust flue gas). I'm pretty sure it needs a 1" clearance around the pipe.
This is a link to the install book.
http://www.homedepot.com/catalog/pdf...f282f25a2f.pdf
07-03-2015, 07:53 AM #3
Thanks, Scott, that is exactly what I was going to look for. It's not visible in my photo, but there is no tpr discharge line, so I had to recommend a plumber anyway.
07-07-2015, 03:35 AM #4
