Results 1 to 1 of 1
12-31-2015, 12:49 PM #1
My indoor AC/water heater pump unit is SWEATING inside
Recently had issue with high humidity in my apartment.
I went inside my unit that's outside in a closet by the front door.
I cleaned out the drain pipe and poured some clorox to clean mildew from drain pipe.
The unit cools down just fine but since I did this the unit's sweating inside to the point that all the insulation, even vertical panel are soaking wet.
It actually is dripping from cabin,YIKES!
Was it me that did this?
Did I create an issue with condensation ?
