Results 1 to 25 of 25
Thread: Rheem Heat Pump Issue
01-05-2016, 08:19 PM #1
Anybody see something wrong here?
01-05-2016, 08:28 PM #2
Re: Rheem Heat Pump Issue
01-05-2016, 08:39 PM #3
01-05-2016, 09:29 PM #4
Here's the answer.
01-06-2016, 01:29 AM #5
Shades of a Canadian reincarnation.
01-06-2016, 08:34 AM #6
What is the point of this thread?
01-06-2016, 09:58 AM #7
01-06-2016, 10:08 AM #8
To speculate on the type tape used? I looks like Gorilla Tape. No cheep Dollar Store duck Tape there.
Or why the trap was cracked in the first place >???
Or why the HI he had for purchase didn't note it in report >???
Or why David try to force what would not flex rather that correct the issue >???
Or > ????????????????????
01-06-2016, 02:34 PM #9
The tray under the bottom cannot be pulled out because trap is in the way. Different pics.
But I agree, enough of Guess the problem posts. Give us something to go on. Then we can laugh with you.
01-06-2016, 02:57 PM #10
01-07-2016, 04:37 AM #11
So now the rules dictate that the post has to meet the critique of critics? Very professional.
01-07-2016, 06:23 AM #12
01-07-2016, 07:23 AM #13
The ruQUOTE=Raymond Wand;263080]So now the rules dictate that the post has to meet the critique of critics? Very professional.[/QUOTE]
Post numbers 3 and 4 show the intent of the original post.
Nothing in there for a question or education.
The rules haven't changed - being professional is still the goal.
01-07-2016, 08:45 AM #14
Jerry it may not be educational for you or a question for your liking, but what about those that are new to the biz, or enjoy pictures of finds from inspections? Not everyone is seasoned inspector nor does every post require an explanation.
Remember a picture is worth a thousand words and professionalism is part of being courteous.
01-07-2016, 09:40 AM #15
Now lets play nice
The problem with the post is that from the 1st posting pict there is no way to see that there is a filter . Maybe a pict from a different angle. But from what I saw on my screen not really detectable.
Then with the drain lines located as they are you would expect the filter be else where. Again it a mater of angle/perspective to note filter existence at all. Damaged lines are a common item to find and most often do not make for a search to see what damaged them or why.
Lets add into the equation that if there is another filter in the return system, which is quite possible. You would not look for what we can not see from the posting pict perspective unless that tid-bit of information was provided.
To often something is totally obvious when you have it figured out. But not obvious until then.
Sooooooo, The thread posting presentation was in want of a better execution. Then again the OP David may have been trying to develop something other than just an interesting thread. Previous posts were dealing with HI report issues with his own properties he was selling and buying. Not saying there was something nefarious in the OP, just something that does cross ones mind at times.
Patience and Professionalism combined with a little Charity is often needed.
01-07-2016, 12:14 PM #16
Raymond,
I was not the only one to try to decipher what the original poster's intent was. I am always open to learning more, so, if you would, please explain what could be educational about this question:
Poor focus of the photo?
Poor composition of the items in the photo?
What is the question asking for?
01-09-2016, 05:15 PM #17
Actually, the purpose of this post was to educate those who may not be familiar with this type of unit. I admit, I could have presented it better. This has nothing to do with my previous HI experiences. My inspector for this property missed this, but I do not blame him or hold him responsible. I was very happy with his services.
The problem is with the drain lines blocking the removal of the filter. I found this while trying to troubleshoot "no heat" issues.
- - - Updated - - -
To share and maybe educate. I've learned a lot from this forum and like to contribute.
01-09-2016, 05:21 PM #18
01-09-2016, 05:34 PM #19
01-09-2016, 06:04 PM #20
01-09-2016, 06:19 PM #21
01-09-2016, 07:45 PM #22
01-10-2016, 11:00 AM #23
01-12-2016, 06:49 AM #24
01-12-2016, 05:34 PM #25
Thanks for the clarification. I thought maybe the taped pipe was a repair.
You could install threaded connectors so that the pipes can be moved aside. I'll bet the filter is filthy.
Your inspector should have pulled out the filter.
It is one of the things I do as a routine, pull it partway out, snap a pic, shove it back, takes just that much time and is helpful info for a buyer - Hey, you have a filter (that needs to be serviced X times a year.)
